Hello Guest it is November 22, 2026, 07:25:01 AM
Author Topic: jerky servo Mach3  (Read 26465 times)
Offline Ed
  •  15 15
Re: jerky servo Mach3
« Reply #10 on: February 11, 2008, 10:46:29 AM »
This is my xml file.
« Last Edit: February 11, 2008, 12:57:43 PM by Ed »
« Reply #11 on: February 11, 2008, 03:29:47 PM »
Ed
looked through your xml and dont see anything wrong. Did notice you had different steps per unit for each axis though, is this correct?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #12 on: February 11, 2008, 03:45:25 PM »
Hi, Ed
Mach may be trying to adjust your vel/Accl. when your setting dif. kernel speed's back and forth, A re-start is req. after change and then a Re-tune of vel/Accl.
Did you use g00 moves or Shift + Arrow key to tune your Velocity & Acceleration settings ?
On the Program Run Screen what's your Feed-rate set to ?, Hit the TAB key, What's the Slow-Jog Rate set to ?
If thy aren't set to 100 then your tunning is probably way off.
It's volunteer's around hear for the most part.
Hope this Helps, Chip
