Hello Guest it is October 11, 2026, 11:21:54 PM
Author Topic: Has Mach got user timers  (Read 22475 times)
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« on: April 29, 2006, 03:36:24 AM »
I have looked in the Mach docs and can not find any reference to timers.  The thing I was looking for was some way of turning on a auto lube pump every 10 minutes for about 30 seconds.
Is there something I have missed?
Graham.
ynneb
Re: Has Mach got user timers
« Reply #1 on: April 29, 2006, 04:21:36 AM »
Good question and a good idea to implement if it hasnt.
« Reply #2 on: April 29, 2006, 06:20:14 AM »
There is kinda... If you do a maro pump you can turnn things on and off by looking at the time the job has been running..
www.newfangledsolutions.com
www.machsupport.com
Offline fdos
  •  326 326
« Reply #3 on: April 29, 2006, 01:01:29 PM »
Graham
You could use an external timer.  Or in the case of my current project the pump does it's own timing via a sycronous motor, which triggers the pump every 6 minutes (adjustable)
Wayne..
  •  2,785 2,785
« Reply #4 on: April 30, 2006, 03:32:55 AM »
thanks for the ideas,  I still think a couple of timers built into mach would be a good idea, not just for lube pumps.
Graham
« Reply #5 on: July 13, 2006, 12:37:48 AM »
Hi
I am trying to measure a time period looking at the time the job has been running but...
GetDRO(14) returns 0.??
Is 14 the correct Function code to read this time?
Thanks Achilles
« Reply #6 on: July 13, 2006, 12:40:52 PM »
There are timers built into MAch3 :) I didn't know about them till the other day  :o
I think there is a bug in reading the Elapsed time... I will look into it :)
www.machsupport.com
« Reply #7 on: July 13, 2006, 04:07:34 PM »
I did it with time() vb script function
Thanks anyway
