Mach Discussion => General Mach Discussion => Topic started by: Graham Waterworth on April 29, 2006, 04:36:24 AM
I have looked in the Mach docs and can not find any reference to timers. The thing I was looking for was some way of turning on a auto lube pump every 10 minutes for about 30 seconds.
Is there something I have missed?
Graham.
Good question and a good idea to implement if it hasnt.
There is kinda... If you do a maro pump you can turnn things on and off by looking at the time the job has been running..
Graham
You could use an external timer. Or in the case of my current project the pump does it's own timing via a sycronous motor, which triggers the pump every 6 minutes (adjustable)
Wayne..
thanks for the ideas, I still think a couple of timers built into mach would be a good idea, not just for lube pumps.
Graham
Hi
I am trying to measure a time period looking at the time the job has been running but...
GetDRO(14) returns 0.??
Is 14 the correct Function code to read this time?
Thanks Achilles
There are timers built into MAch3 :) I didn't know about them till the other day :o
I think there is a bug in reading the Elapsed time... I will look into it :)
I did it with time() vb script function
Thanks anyway
