Hello Guest it is November 13, 2026, 09:57:51 AM
Author Topic: output on/off  (Read 13789 times)
Offline ayhan
  •  12 12
output on/off
« on: February 08, 2008, 06:26:33 AM »
Hello ,
I am building 5 axes machine.
And need to command to a welding machine , It sould start to weld and stop and start again while axes are running.
what should I write and insert in g-kode lines
"output 1 on" and "output 1 off"  ? Just like this ?
Best regards
Ayhan Caglar
Re: output on/off
« Reply #1 on: February 08, 2008, 08:18:10 AM »
How do you have it connected? If you have it connected a single relay then you just need to write a macro and place it in the macro folder for the profile you use.
 If you name the macro M80 (presuming you dont already have a M80 macro) then when you call M80 from your code it will turn the welder on. You will also need a macro to turn it off and you could call that M81 for example.
If for instance your relay is connected to Output 4 then your macro to switch on would read
ActivateSignal (OutPut4)    ' Switches on via output 4
For the Off macro it would be
DeActivateSignal (OutPut4) ' Switches off output 4
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: output on/off
« Reply #2 on: February 08, 2008, 10:45:06 AM »
Hood - where can I get a list of the Mach3  Visbasic commands your have just quoted. I know a few that I have picked up from all the various tutorials, but I haven't come across a full list of them yet
Jim
Re: output on/off
« Reply #3 on: February 08, 2008, 01:12:57 PM »
Jim
Dont know Jim, I have looked about for such a thing but never found it :(
