Hello
Guest
it is
October 21, 2026, 10:01:52 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
FAQs
cannot use gen config screen cannot view entire screen
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: cannot use gen config screen cannot view entire screen (Read 27538 times)
bigedwood
1
on:
February 04, 2008, 05:00:43 PM »
???try as i may, i cannot find a post to change the gen config page size so i can view all fields. i have touch screen 640x480 res. no adjustment in res available with windows fields?? any help out there
?newbie
Logged
Greolt
956
Re: cannot use gen config screen cannot view entire screen
Reply #1 on:
February 05, 2008, 05:19:40 AM »
Interested to see any replies.
I have the same problem. 800 x 600 screen.
Even worse for the Shuttle Pro set up screen.
Greg
Logged
eggoaust
1
Reply #2 on:
March 15, 2008, 03:19:48 AM »
If you change your screen resolution to 1024 x 768 - BUT MAKE SURE you leave colour set to Medium 16 bit - all should be fine.
If you are unable to set/change your screen resolution you may need to install correct video card driver first.
Eggo
Logged
Print
Pages:
1
Go Up
« previous
next »
