Mach Discussion => FAQs => Topic started by: bigedwood on February 04, 2008, 06:00:43 PM
???try as i may, i cannot find a post to change the gen config page size so i can view all fields. i have touch screen 640x480 res. no adjustment in res available with windows fields?? any help out there ????newbie
Interested to see any replies.
I have the same problem. 800 x 600 screen.
Even worse for the Shuttle Pro set up screen.
Greg
If you change your screen resolution to 1024 x 768 - BUT MAKE SURE you leave colour set to Medium 16 bit - all should be fine.
If you are unable to set/change your screen resolution you may need to install correct video card driver first.
Eggo
