Hello Guest it is November 13, 2026, 09:37:22 AM
Author Topic: Running at Half Scale  (Read 22411 times)
« on: January 26, 2008, 05:57:57 PM »
I've set up everything to spec, I think, But I seem to be running at half scale.
My numbers in mach are correct, but my router is running at what it appears about half scale. What am I doing wrong?
Re: Running at Half Scale
« Reply #1 on: January 26, 2008, 06:05:43 PM »
Make sure you have the scale set to 1 for each axis, you will see it at the right of each of the axis DRO's on the main page. If this is already set to 1 then are you sure you have the numbers right in your motor tuning? if its steppers you have they may be 0.9 degre steppers rather than the usual 1.8 degrees.
« Reply #2 on: January 27, 2008, 07:50:01 AM »
I've double checked everything and the motors and drives are set correctly.2000 steps, 1.8 degree motors. I bought everything as a package from
Automation Direct, so I know everything should work together. The scale is set at 1 on the DRO's. When I manual input values, say as inputting 1 inch I'll get only about .200 so I'm about 1/5th what I should be at. My lead screws are 5 TPI. I can set my drives up to 10000 steps. I reset my drives for 1000 step and I still get a reading of 1/5 of what I should have.
« Last Edit: January 27, 2008, 07:58:09 AM by tz1238 »
« Reply #3 on: January 27, 2008, 08:29:21 AM »
can you give a link to the drives you have?
« Reply #5 on: January 27, 2008, 08:44:11 AM »
OK so do you have them set up for 1/5 microstepping?
If yes then you need to set the steps per unit in Mach to 5000, this is because to move 1 inch you need 5 Revs of the motor, you have to send 200 steps to do one Rev when on Full stepping but five times that for 1/5 stepping so thats 1000 steps per rev. It then follows that you need 5Revs x 1000steps = 5000 steps per inch. Or at least I think it is, I am used to working in mm :)
« Reply #6 on: January 27, 2008, 09:04:31 AM »
I'll give it a try. I actually have them at 1/10, so if I keep that setting the motors would be at 10,000 steps?
« Reply #7 on: January 27, 2008, 09:10:28 AM »
yes thats right 5 turns x 200 steps x 10 (for 1/10 micro) = 10,000 steps to move 1 inch. This is all presuming you have direct coupling of the motors to the screws.
« Reply #8 on: January 27, 2008, 09:32:16 AM »
Great, I'll give it a try and let you know how it worked out. Thanks for all your help.
« Reply #9 on: January 28, 2008, 04:01:49 PM »
Reset my motors and everything is right on the money. Thanks for all your help.
