Hello Guest it is November 17, 2026, 10:19:51 AM
Author Topic: Spontaneous Mach Turn Shut off  (Read 9831 times)
« on: January 23, 2008, 09:54:50 PM »
Hi, i used Mach turn for a whole project and things worked ok.
Now, i output a G-code file from mastercam X, ran it in Mach turn, and the thing shut off. I turned the computer on/off and it did it again.
Basically, after loading the file, Mach turn either shuts off right away, or moments later when i start setting up my job. What's going on?
Has anyone experimienced this?
Re: Spontaneous Mach Turn Shut off
« Reply #1 on: January 24, 2008, 09:30:24 AM »
Do you get any Windows error messages or does Mach just shut down? Can you attach your code so we can see if anything in there is potentially a problem.
