Hello Guest it is November 23, 2026, 04:04:44 AM
Author Topic: Spindle speed control  (Read 10117 times)
Offline tivoi
  •  29 29
« on: January 19, 2008, 04:28:37 AM »
how to automatic control spindle speed with this motor? any try it?
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: Spindle speed control
« Reply #1 on: January 19, 2008, 02:41:48 PM »
I take it your idea is to  hold this in the Z axis and use it for drilling or something similar
Makita is good equipment - BUT - can you control the speed of the tool as it is.
I do NOT mean by pulling a trigger. Is there any system attached to the tool to control the speed.
The enquiry on your other post gave a brief idea of turning it on and off, but speed control is something different.
Mach 3 can control stepper motors without any problem.
Mach 3 can also put out a PulseWaveModulated signal to control Digispeed and similar motor driver boards.
You might be better served finding a motor on which you can control the speed easily, and then fitting a chuck or similar on it, rather than trying to control a hand tool.
Offline tivoi
  •  29 29
« Reply #2 on: January 19, 2008, 05:29:35 PM »
Thanks jimpinder
i have one ideas
this is oginal speed control of makita tools
I'' replace varesistor by LDR
Then using PWM spindle speed genorator analog and control white led >> LDR >> motor speed
is it possible?
thanks you agian
