Hello Guest it is November 11, 2026, 06:37:52 PM
Author Topic: PCB Engraving  (Read 12376 times)
PCB Engraving
« on: January 18, 2008, 03:58:41 AM »
I am desiginig PCB in Protel software. This can generate gerber files of PCB. I want to milling it using Isolation method. I have 3-axis CNC machine controlled by MACH3. Is there any procedure to convert protel gerber file to mach3 code?
Sanlee
Re: PCB Engraving
« Reply #1 on: January 18, 2008, 06:38:31 AM »
Hi, I dont know if this is what you need but heres a link.
http://sourceforge.net/projects/gerbertogcode
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: PCB Engraving
« Reply #2 on: January 18, 2008, 07:22:00 AM »
Hi, Sanlee
Hears a little info on LazyCam posts of gerber file's
http://www.machsupport.com/forum/index.php/topic,5412.0.html
Thanks, Chip
Re: PCB Engraving
« Reply #3 on: January 18, 2008, 01:17:01 PM »
Hi Sanlee,
This bit of software does what you want, I have used it a few times, but with CNCpro and not Mach3. However the Gcode will work in Mach3 I am sure.
www.imsrv.com/deskpcb
Tx Friedrich
