Hello
Guest
it is
October 21, 2026, 08:52:13 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
motor settings and xyz limits cnc9000
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: motor settings and xyz limits cnc9000 (Read 9423 times)
cpcbman
3
on:
January 14, 2008, 07:37:59 AM »
anyone familiar with the CNC9000 from Circuit Specialist Inc, if so any suggestions on motor tuning?
Is there a way to set X,Y,Z limits using machine coordinates if I do not have limit switches installed?
Very new user
Carnoustie, Scotland
Re: motor settings and xyz limits cnc9000
Reply #1 on:
January 14, 2008, 01:13:33 PM »
If you do not have limits you can still set soft limits by jogging your table to an axis extreme and pressing the Ref button for that axis (you want Auto Zero checked ) Then when you set up your softlimits you set the min for axis zero and the max for the axis travel.
Reply #2 on:
January 14, 2008, 01:14:47 PM »
BTW make sure you jog to that position and ref every time you Open Mach as this is the only way Mach knows where your table is.
Print
Pages:
1
Go Up
« previous
next »
