Hello Guest it is September 28, 2026, 11:59:10 PM
Author Topic: New Plugin Available - XBox360 Controller  (Read 93861 times)
Offline Perfo
  •  143 143
Re: New Plugin Available - XBox360 Controller
« Reply #40 on: August 07, 2008, 05:59:28 AM »
I noticed the non self install difference and I've downloaded the latest Mach 3 just to make sure I was on the right version and it did say mach 4 in the window. I'll erase everything and try again. There is a possibility that due to trying to self install it damaged the file somehow. Be right back.
Offline Perfo
  •  143 143
« Reply #41 on: August 07, 2008, 06:57:58 AM »
Ok. I've done a fresh install of everything. I found the smooth stepper plug in was still installed even after going to control panel and saying de install mach 3. When I tried to do it manually it appears even though admins had full control and I was signed in as an admin vista thought I didn't have permission to delete anything in the mach 3 folder so looked as if it had but didn't delete anything. Anyway changed the owner to me and ensured every thing gone. Reinstalled Mach 3 version R2.63 and downloaded Xbox360 plug in. Hmmmm no change as mach 3 boots up the pop up is titled mach 4 and the message is
"plug in DLL defective. Reload" I clicked OK and the next message was (again titled Mach 4) Xbox360controller.dll-defective plug in found...ignoring" then Mach 3 continues to load up but without the plug in.
Offline Leed3
  •  162 162
« Reply #42 on: August 07, 2008, 10:23:41 PM »
I have just been advised by Artsoft that there is a problem with the download.  I am trying to figure out happened to the file and will let you know as soon as I have an answer. Hopefully, that will be tomorrow.
Lee
Offline Perfo
  •  143 143
« Reply #43 on: August 08, 2008, 01:54:37 AM »
Ah. It's always good to know that it wasn't my fault......then again it may still be my fault, just not totally. :) I'll keep my eyes on the thread and give it another go when appropriate.
thanks
« Reply #44 on: August 08, 2008, 05:20:58 AM »
Lee, I haven't had a look at the plug-in yet but just wanted to say thanks. Another great gift from one of our fine members. I must say it is really nice to have a lot of great people here.
« Reply #45 on: August 28, 2008, 03:11:32 AM »
Hello,
i bought a controller this week, install the new driver (running ok in control panel), the new plugin 2.0, and configure Mach3 but when i start Mach 3 (Version R3.041 registered), i receive an
error that say that controller batterie are empty. But control panel of the XBOX 360 controller say that the batterie are full.
I changed also the batterie with 2 news bat.
Any idea ?
Fabrice
« Last Edit: August 28, 2008, 03:29:15 AM by Fab6657 »
« Reply #46 on: September 03, 2008, 02:34:10 PM »
Not knowing anything about the Xbox 360, is there any other hardware needed if I get a wireless Xbox 360 controller? Looking at the web sites, the Xbox 360 has wireless built into it, what do we need on the PC to use a wireless controller?
« Reply #47 on: September 04, 2008, 06:31:54 AM »
Hello,
you need the Microsoft Xbox 360 Wireless Receiver for Windows, that is sell with a controller, near the 50€.
It is also sell alone without Joypad for 20$.
http://www.xbox.com/en-US/hardware/x/xbox360wirelessgamingreceiver/
Does anybody have an idea for the batterie message. I cannot use the xbox pad actually.
Fabrice
« Last Edit: September 04, 2008, 06:36:29 AM by Fab6657 »
Offline Perfo
  •  143 143
« Reply #48 on: September 04, 2008, 08:03:55 AM »
hello fab. I haven't got one of these nor do I know much about them. Does the battery warning come up as soon as you put new batteries in it? or does it wait a while? If it does wait a bit it may be caused by either a fault in the device draining the battery or (quite common with radio controlled gear) it can't make a connection with the Base unit..IE it continually scans even when you think it's not on. Like I said I thought it was worth a mention for a shot in the dark type thing. Can you borrow someone else's controller and see if this does the same?
« Reply #49 on: September 04, 2008, 09:39:07 AM »
Hello,
the message are directly in Mach3 after the start of the program. This Pad run well under Windows (only in the property control panel). I have nothing else to test on this PC.
Strange ! I will test it on an other PC.
Fabrice
