Hello Guest it is November 13, 2026, 09:59:51 AM
Author Topic: Wizzard tutorial?  (Read 22588 times)
Wizzard tutorial?
« on: April 24, 2006, 11:37:11 AM »
Are there any tutorials or videos about making wizards?
What would be cool, would be to have the ability to program the operation of a machine (not necesarily a XYZ machine) like a plastic injector, where you could input the number of pieces you want to produce, input all the times for the different operations, amount of plastic to shoot, etc...
That would allow Mach 3 to be used in other aplications, like the coil winder machine, the example above etc...
Like user az7733 said: Teach us to fish!
Best Regards
Fernando
Re: Wizzard tutorial?
« Reply #1 on: April 24, 2006, 12:56:01 PM »
When I have time I will make a video...
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: April 24, 2006, 01:05:25 PM »
Thanks Brian,
Looking forward to it.
Just starting to get feet wet with the mach 2 customization document.
Regards
Fernando
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« Reply #3 on: April 24, 2006, 09:32:07 PM »
Fernando:
 Also, a great way to figure out wizard is to open up the digitize wizard in Screen 4. Get used to all the controls and how they ar eplaced. Notice that several of the buttons are set to run MAcros..
Now open up Mach3, run the digitize wizard, select config/edit script button. Notice all buttons that have scripts in them start to flash. Click on one and it will show the script in it.. Look at all the scripts,
how to write a wizard will slowly become very clear. Its just buttons, and scripts and DRO's.. Thats all. :)
Art
« Reply #4 on: April 24, 2006, 09:55:40 PM »
Thanks Art,
It sounds simple enough, just need to learn a little of VB scripting.
I am surprised I havent seen more machines being controled by Mach (non cartesian).
I´ll give it a go.
Regards
Fernando
« Reply #5 on: April 24, 2006, 10:05:39 PM »
Hey art,
I am getting the following error when I double click on any button of the digitizing wizard on screen designer 4
Text file for function calls missing.. please reinstall..
Fernando
Offline ART
  •  1,703 1,703
« Reply #6 on: April 25, 2006, 06:08:21 AM »
F:
   When you unzipped Screen4 , there were three text files in there as well as Screen4.exe. All 4 must be copied to the MAch3 folder. If not, that error is output..
Art
