Hello Guest it is November 01, 2026, 01:03:42 PM
Author Topic: LazyCam interpretation of Apertures in Gerber (GBR) files  (Read 14220 times)
« on: January 10, 2008, 09:44:00 PM »
Hello all,
I'm trying to import a gerber file into lazycam that contains the location of various pads (or apertures in gerber terms).  Regardless of their shape and size, lazycam interprets them as a circle of radius 5 mil.  Does lazycam not recognize apertures in gerber files, or is this just a setup problem?  I've set the tool diameter to smaller than the smallest pad/aperture dimension so this shouldn't be limiting the size of the cuts.
Has anyone had success converting apertures in gerber files into accurate shapes in lazycam?
EDIT:
I should clarify that my intention is to mill out the apertures as shapes and not 'flash' them.
Attached is the gerber file:
Code: [Select]
%FSLAX23Y23*%
%MOIN*%
G70*
G01*
G75*
%ADD10R,0.036X0.048*%
%ADD11R,0.050X0.050*%
%ADD12R,0.025X0.040*%
%ADD13R,0.060X0.066*%
%ADD14O,0.040X0.016*%
%ADD15R,0.040X0.016*%
%ADD16R,0.040X0.025*%
%ADD17R,0.030X0.030*%
%ADD18R,0.050X0.060*%
D10*
X9580Y8151D02*
D03*
X9709D02*
D03*
X10100Y8461D02*
D03*
X9971D02*
D03*
D11*
X10005Y8091D02*
D03*
X10105D02*
D03*
X9500Y8191D02*
D03*
Y8291D02*
D03*
X10015Y8381D02*
D03*
X9915D02*
D03*
X10390Y8371D02*
D03*
Y8471D02*
D03*
Y8221D02*
D03*
Y8121D02*
D03*
X10220Y8381D02*
D03*
X10120D02*
D03*
X9830Y8176D02*
D03*
X9930D02*
D03*
X9690Y8291D02*
D03*
X9590D02*
D03*
X9690Y8356D02*
D03*
X9590D02*
D03*
X10290Y8296D02*
D03*
X10222Y8301D02*
D03*
X10122D02*
D03*
X9790Y8376D02*
D03*
Y8276D02*
D03*
X10390Y8296D02*
D03*
D12*
X9412Y8199D02*
D03*
Y8301D02*
D03*
X9375D02*
D03*
X9450D02*
D03*
X9449Y8199D02*
D03*
X9375D02*
D03*
D13*
X10075Y8176D02*
D03*
X10223D02*
D03*
D14*
X9871Y8323D02*
D03*
Y8298D02*
D03*
Y8272D02*
D03*
Y8246D02*
D03*
X10060Y8323D02*
D03*
Y8298D02*
D03*
Y8272D02*
D03*
D15*
Y8246D02*
D03*
D16*
X9695Y8491D02*
D03*
Y8454D02*
D03*
Y8416D02*
D03*
X9593Y8417D02*
D03*
Y8491D02*
D03*
D17*
X9443Y8441D02*
D03*
X9481Y8351D02*
D03*
X9405D02*
D03*
D18*
X10285Y7881D02*
D03*
Y7791D02*
D03*
X10280Y8701D02*
D03*
Y8791D02*
D03*
M02*
« Last Edit: January 10, 2008, 10:08:53 PM by mass »
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: LazyCam interpretation of Apertures in Gerber (GBR) files
« Reply #1 on: January 11, 2008, 04:29:22 PM »
Hi, Mass
Can you give us a screen shot of what it should look like ?
Thanks, Chip
« Reply #2 on: January 11, 2008, 04:55:05 PM »
this is what the actual gerber looks like:
and this is what lazycam gives:
notice that the entity selected in lazycam is a circle of radius 5 mil but the actual pad in the gerber is a rectangle 60x66 mil
Offline Chip
  •  2,055 2,055
« Reply #3 on: January 11, 2008, 08:49:13 PM »
Hi, Mass
With a web search I found this on GBR Save.
Save: Arc Supported, Chord Supported, Circle Supported, Lnes Supported, Polygons Supported, " Rectangle Not Supported "
Maybe a different .### (WMF or EMF) format will save them and LC can read It, Not an Expert Hear.
Thanks, Chip
« Last Edit: January 11, 2008, 08:58:54 PM by afn09556 »
