Hello Guest it is November 01, 2026, 01:05:40 PM
Author Topic: Tool save for Turn  (Read 29080 times)
Offline Ben
  •  79 79
Re: Tool save for Turn
« Reply #10 on: January 06, 2008, 04:50:18 PM »
Whew, my mouse finger is getting tired. I'm making very slow progress. When I load my dxf file I have to optmize it and thats the only difference I do but the last step turns out wrong. I'm using inches it looks like you are using MM. When I copiec your dxf image to my dxf your on was about 20 times bigger.
« Reply #11 on: January 06, 2008, 05:36:29 PM »
Yes I do use mm, (i'm in uk) you need to alter your tool settings to reflect the units you're using. Try this..
« Reply #12 on: January 06, 2008, 05:42:37 PM »
oops.. with this... it's in "". Bear in mind it's only a quick example.
Offline Ben
  •  79 79
« Reply #13 on: January 06, 2008, 07:10:06 PM »
 ;D
Thanks Freddy, job well done. You stuck with me to the very end and it all works. Ben
Offline Ben
  •  79 79
« Reply #14 on: January 07, 2008, 07:30:26 AM »
Also somewhere in all this I am now able to save a tool type. Go figure. Ben
