Hello Guest it is October 12, 2026, 04:21:27 PM
Author Topic: TCP Modbus I/O organizational documents for your use...........  (Read 10668 times)
« on: December 31, 2007, 03:47:03 PM »
I am working on a Large Machine with alot of TCP/Modbus I/O.  I had to track alot of info on what was what, and where it went and what it did.
So, I made a MS Word TCP Output Mapping document and a TCP Input Mapping document. Both are set up as tables and are editable for your use. Just Change the information at the Top to reflect your situation. The one I put up is for using 2 PLC's one for input and one for output.
The system shows the flow of data going in to mach and out from mach, as it travels to and from: The PLC, Mod Bus, Brains, Macropump (if applicable), Functional discription, and Data/Target Page.
It could easily be adapted for Serial Modbus, or just "Record keeping" on your systems I/O.
they are attached as a Zip called:  TCP_IO.zip
Scott
Re: TCP Modbus I/O organizational documents for your use...........
« Reply #1 on: December 31, 2007, 06:19:27 PM »
Thanks Scott.
