Hello Guest it is October 21, 2026, 04:21:26 AM
Author Topic: PNP LPT Port  (Read 11741 times)
PNP LPT Port
« on: December 28, 2007, 06:30:50 PM »
Today I purchased a 2nd LPT port for my computer. It does not use standard LPT port addresses. I want to add a second set of motor controllers to my computer and need to use a 2nd port to do that.
Has anyone here tried to use a PNP LPT Port w/ Mach3 and gotten it to work? If so please post here how you did it.
Many thanks -SS
Re: PNP LPT Port
« Reply #1 on: December 29, 2007, 02:22:23 AM »
Have you put the address that shows in device manager into the port 2 address in Mach?
Re: PNP LPT Port
« Reply #2 on: December 29, 2007, 07:13:08 AM »
I have tried it and it is not working. The hex address in device manager is
D000 instead of the standard 278 or 378 etc...
Thanks -
__________________
Re: PNP LPT Port
« Reply #3 on: December 29, 2007, 09:16:17 AM »
If it shows as D000 then entering that into the second port address should work, mine is 9C00 and that works fine.
Re: PNP LPT Port
« Reply #4 on: December 29, 2007, 11:30:15 AM »
I went and bought a new card and it works fine. I could not find a jumper based legacy card, this is another PNP. It did not come with drivers so had to download them. The I/O address is CC00 and it works fine.
Many thanks for all the help.
