Hello Guest it is September 16, 2026, 02:56:33 PM
Author Topic: Non-parallel (rotated) datum  (Read 10429 times)
Offline Bodini
  •  216 216
« on: December 21, 2007, 10:38:33 AM »
Is it possible to set up an offset datum that is not on a level plane?
  I mean for instance, at X0, mach's z would read 1, and the cutter would indeed be 1 unit from the work surface.  then at say x12, mach's z would also read 1, but the cutter would actually be 2 units above the work surface.
Wait a second, suddenly g68 comes to mind as I write this out.
Then I go to the manual and see in 10.7.20, "this only allows rotation when the current plane is X-Y".
And now me thinks this cant be done.  right, wrong?
-Nick
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Non-parallel (rotated) datum
« Reply #1 on: December 21, 2007, 10:48:46 AM »
You can feed between 2 points on 2 different fixture offsets.
e.g.
G54 G00 X0 Y0 Z1.
G55 G01 Z2. F100.
If its any good to you ?
Graham.
Offline Bodini
  •  216 216
« Reply #2 on: December 21, 2007, 10:55:02 AM »
I see what you are doing Graham, thanks for the input.
I was trying to skip the gcode and set the datum on a slanted plane so that even in jogging, mach would compensate for the plane being non-parallel to the machine coordinate Z.
-Nick
  •  2,785 2,785
« Reply #3 on: December 21, 2007, 11:01:45 AM »
With you now, you want 3D jogging.
You could ask  ;)  but I think not   :(
Graham.
