Hello
Guest
it is
September 05, 2026, 04:30:29 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Probe normally open/close?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Probe normally open/close? (Read 13024 times)
TT350
113
on:
December 16, 2007, 08:39:18 PM »
Hi guys I wired a probe into Mach3 today.
When I tested my probe I found that it needs
to be normally open.
My probe is normally closed,
How and where do configure Mach to work with
this probe.
Chris
Chaoticone
5,624
Precision Chaos
Re: Probe normally open/close?
Reply #1 on:
December 16, 2007, 08:44:22 PM »
Config, ports and pins, inputs. Scroll down till you see probe and change tha active low. If it is a red x, click on it to change it to a green check. Click OK at the bottom and exit.
If you could see the things I have in my head, you would be laughing too.
TT350
113
Reply #2 on:
December 16, 2007, 10:27:39 PM »
I'll play around with it tomorrow and let you know how it works thanks !
Chris
stirling
2,188
UK
Reply #3 on:
December 17, 2007, 07:21:20 AM »
Mach's probe default is active high (a cross in active low) which is correct for a NC probe, which is what you say you have, so something doesn't seem to add up here unless you've already changed it in ports n pins.
Last Edit: December 17, 2007, 07:28:31 AM by stirling
Razordance Torch Height Control
TT350
113
Reply #4 on:
December 18, 2007, 07:14:42 AM »
Thanks for the quick response guys, it works!!
Print
Pages:
1
Go Up
« previous
next »
