Hello Guest it is October 21, 2026, 06:48:19 AM
Author Topic: Help building a power supply  (Read 16449 times)
« on: December 15, 2007, 09:54:47 AM »
Hello all.
Im getting into building my first power supply. Im pretty comfortable assembling electronic parts. but determining which ones I need is another story.
I need a little help selecting the capacitors I need for my project. I have a transformer that is more than adequit for my purposes. I bought an Antek torodal transformer and bridge rectifier from homeshopcnc.com but they no longer sell the transformers or the bridge rectifiers. any way the transformer is rated for 1000VA and has dual 45V output windings.
If you go to the Antek website. It is
http://www.toroid-transformer.com/
the transformer Item number is
AN-10445
now I am really only running two small nema 23 servo's and a RS23-370 oz stepper off this huge supply. so Im not really sure what size capacitor to use to build the supply.
any help would be appreciated.
also a source to purchase them would be helpful as well.
Re: Help building a power supply
« Reply #1 on: December 15, 2007, 09:56:22 AM »
Oh Im using Geckos to drive them if that helps.
and the servo's are have a terminal voltage of 60 volts
I got them from homeshopcnc as well.
Chris
« Reply #2 on: December 15, 2007, 10:32:55 AM »
Whats the current ratings of your motors?
« Reply #3 on: December 15, 2007, 04:12:54 PM »
the servos say 3.5 A continuous current and 20 A peak current and the stepper will be wired in parralel which calls for 5 Amps.
Hope thats what you need
« Reply #4 on: December 15, 2007, 05:33:07 PM »
You probably are looking at a minimum of 12,000uF, but more would do no harm.
« Reply #6 on: December 16, 2007, 08:22:35 AM »
Oh wait there rated at 33000 mF not uF
is there a difference Im assuming there is.( sorry, dont know much about capacitors)
Chris
« Reply #7 on: December 16, 2007, 10:31:12 AM »
They are uF if you look on the Capacitors themselves you will see it, the guy has said they are micro Farads in the description but has said mF in the title which means  milli Farrad which is wrong. They would be very nice capacitors if they were mF ;)
Anyway, yes they should do nicely.
« Reply #8 on: January 17, 2008, 07:05:08 AM »
Hello all.
AN-10445
Hello!
I'm sure this will help you out, as the following link properly guides me in making a perfect power supply!
http://campbelldesigns.net/how-to-build-a-power-supply.php
Read everything especially the PDF File, I'ts very helpful!
Good Luck!!!!
