Hello Guest it is November 04, 2026, 03:47:44 PM
Author Topic: Plasma conections  (Read 11566 times)
Plasma conections
« on: December 11, 2007, 06:19:38 PM »
Help!!!!! I need to connect the plasma to the machine, dont know how, I only have one free pin , #1 , i havent find in mach manuals about this conection, is the same PWM, or the spindle?
Luis
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Plasma conections
« Reply #1 on: December 11, 2007, 07:39:14 PM »
Hi, Luis
Pin 1 is an output pin, You can use it to turn on your plasma cutter, Ports&Pins, Output Signals, Output#2, ("Check" Port#1, Pin #1, set Act/Low/High as Needed).
M3 will turn it on, M5 will turn it off, Need to use a small 5 volt relay(reed, miniature or Best a solid state relay}.
Hope this Helps, Chip
« Reply #2 on: December 11, 2007, 09:24:34 PM »
Ok, then I conect a wire to the pin #1, its only one wire? any other to ground or not? check disable spindle relays or uncheck? M3 and M5 in engine config relay control?
 Certainly it helps... a lot, I have been all day looking for this...
 Luis
To Gnd. un-check
Chip
« Last Edit: December 11, 2007, 11:55:30 PM by afn09556 »
