Hello Guest it is November 01, 2026, 10:06:13 AM
Author Topic: LAZYCAM Layer control  (Read 35116 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« on: April 19, 2006, 02:53:28 PM »
Hi, Art and Brian
I have been working with lazycam it's really nice I don't now what
functions are implemented at this point. Using Mach3D1.90.028
I have uploaded a file in Lazycam folder test55.dxf a turbocad ver. 8
some time ago never got a responce.
It's a 3 layer dxf one object per layer, hear is what i find.
While layer control shows 3 layer's only layer 0 has objects.
If I click on 0,0 Target, program end's with prompt to send error
report. This is the start point for first object on layer 0, can't set
leadin.
Also if you highlight the first object to move the leadin and click the leadin location the same thing happen's.
I've included an attachment of the file hear
Thank's Chip
Re: LAZYCAM Layer control
« Reply #1 on: April 19, 2006, 08:31:25 PM »
Thank you for the file! I will have a look at it.
www.newfangledsolutions.com
www.machsupport.com
Offline Chip
  •  2,055 2,055
« Reply #2 on: April 19, 2006, 11:30:27 PM »
Hi, Brian
The file i sent you will show three layer's when imported back into turbocad and rino.
Thank's Chip
Offline Chip
  •  2,055 2,055
« Reply #3 on: May 01, 2006, 01:20:34 PM »
Hi, Brian
Have you had a chance to look at this problem.
Thank's Chip
« Reply #4 on: May 01, 2006, 03:26:52 PM »
Yeah but Art is the layer Guy :) I think in the next 3 or 4 days there it is going to be full time LCAM now that the Grex seems to be running good.
www.machsupport.com
Offline Chip
  •  2,055 2,055
« Reply #5 on: May 02, 2006, 12:05:01 AM »
Hi, Brian
Thank's for the fast reply, It's not just the layer's in my post, but that's ok, I now you guy's are swamped with issue's.
I'll re-post them in a few day's
Thank's Chip
« Reply #6 on: May 02, 2006, 06:06:14 AM »
It seemes to work here... Is this what it should look like?
www.machsupport.com
Offline Chip
  •  2,055 2,055
« Reply #7 on: May 02, 2006, 09:15:58 AM »
Hi, Brian
If I load this file with lazycam in default as drawn with no leadin's on, then try to set the leadin at the bottom left 0,0 / target, it error's out and want's to send an error code to microsoft, also if I try to set a inside cir. leadin  on the triangle, far right side it's on the outside and if you set an outside it's on the inside, just backward's.
Just some problem's to look at.
Thank's Chip
« Reply #8 on: May 02, 2006, 10:51:22 AM »
I think I have that problem fixed in the Rev that I have ... I will check it out.
Brian
www.machsupport.com
Offline Chip
  •  2,055 2,055
« Reply #9 on: May 06, 2006, 11:46:15 AM »
Hi, Brian
When are you guy's going to post all these updates.
Thank's Chip
