Hello Guest it is November 11, 2026, 11:00:18 AM
Author Topic: Pairing motor with sensorless vector drive  (Read 10244 times)
« on: December 06, 2007, 07:05:24 PM »
I have a potentially stupid question to ask...
What do I need to consider when pairing a motor with a VFD?  Specifically, I have a couple vector drives, specs here:
http://www.geindustrial.com/products/buyersguide/Sec_12AF-300E$.pdf
they are 5hp GE sensorless vector drives.  What do I need to look for in a motor to take advantage of the vector benefits of the drive?  I read in the manual that it needs to be a 2, 4, or 6 pole motor...anything else?
-Ryan
Offline KTM
  •  92 92
Re: Pairing motor with sensorless vector drive
« Reply #1 on: December 07, 2007, 02:35:58 PM »
It depends on what you would like to us the drive for.
If you only require it for the spindle at close to synchronous speed then you can use a normal motor,
but if you are using it for a low rpm, high rpm or constant start/stop operation then it is better to use an inverter motor
which has seperate windings for the cooling fan or use an external cooling fan - at high rpm the motors fan will draw higher
current from the motor and may even stall the motor.
Regards
KTM
