Hello Guest it is November 13, 2026, 08:21:01 PM
Author Topic: Need Some Help!!  (Read 10166 times)
Offline wdp67
  •  31 31
Need Some Help!!
« on: December 03, 2007, 09:02:42 PM »
Hi all, I downloaded V2.61 tonight and have it installed on a computer with no machine hooked up. I tried to edit a button script by pasting a script into the auto tool zero button. When I press the button I get an error message that says Compile error: Syntax error. I have this same script on my machine computer that has an older version of Mach3 and it works there. I am just glad I did not install the updated version there yet. Any ideas what I may be doing wrong?
Walt
Re: Need Some Help!!
« Reply #1 on: December 04, 2007, 06:05:58 AM »
Walt, lots of the guys here are really good with VB. Might help if you will post the code.
Offline wdp67
  •  31 31
« Reply #2 on: December 04, 2007, 11:28:39 AM »
Thanks for the reply, but I figured it out and got it working, I deleted all the comments and it worked. Don't know why because the comments are in the script on the machine and it works, but at least I got it functioning!
Thanks a lot!!
Walt
