Hello Guest it is November 13, 2026, 07:57:37 PM
Author Topic: Entering HotKey numbers  (Read 12352 times)
« on: November 25, 2007, 11:30:57 AM »
Hi All,
I use Mach3Turn V2.6 and  in   Engineconfiguration- Inputsignals,  i am trying to enter a Hotkeynumber
When i do, i get a Popupscreen witch tells me to hit a Key.
What i want is, just to  enter a number like 1000 or 1003 etc; this seems to be unable.
Can anyone tell me what i am doing wrong???
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Entering HotKey numbers
« Reply #1 on: November 25, 2007, 12:01:18 PM »
Hi, Dikkieduk
It's set up for key #'s, Shift  P = 1104, Ctrl Shift P = 33872 (Keyboard Scan codes), to re-zero click on the Hotkey and click on the close window X.
Hope this Helps, Chip
« Reply #2 on: November 25, 2007, 12:37:19 PM »
Thanks for your help Chip ,
But i should have told you ,that i've been trying to set up
some external pushbuttons like start-stop etc.
Offline Chip
  •  2,055 2,055
« Reply #3 on: November 25, 2007, 01:43:15 PM »
Hi, Dikkieduk
Look at Config, "System Hotkeys", Enter Trigger#, Then OemCode for "Start", Then in Ports & Pins, Inputs, Trigger# set to port and pin.
You could use Brain's, Operator, "Brain Editor" to do it, Configure an input in Ports & Pins, Input # to your external button.
Then Brain Editor, Look at the video's on Brain's Above under "Tutorials".
Describe your setup a little more, Well help if needed.
Many ways to do it, Let US now.
Thanks, Chip
« Last Edit: November 25, 2007, 02:10:31 PM by afn09556 »
« Reply #4 on: November 26, 2007, 04:27:34 AM »
Thanks Chip , working fine now.
