Hello Guest it is August 19, 2026, 06:00:23 PM
Author Topic: mach2 and G76  (Read 33475 times)
mach2 and G76
« on: April 16, 2006, 06:56:17 PM »
is there a way to use G76 to make threads with mach 2 i wish to make 5/8 11 threads and i program my part by hand thank you for your time Marcel Beaudry
Re: mach2 and G76
« Reply #1 on: April 16, 2006, 07:48:59 PM »
load up Mach3 and use the simple threading wizard... This should get you cutting nice threads in no time!
www.newfangledsolutions.com
www.machsupport.com
Re: mach2 and G76
« Reply #2 on: April 16, 2006, 08:40:54 PM »
dear sir
i got mach2 registered and it works very well with my lathe i am not sure how to transfer to mach3 . the lathe was sold to me with the software .i bought the license from art and i am not sure how to transfer all the info and have a lathe that still work
Re: mach2 and G76
« Reply #3 on: April 16, 2006, 08:59:06 PM »
PLease post the XML file that you are running and I will make it so you can run Mach3 ... You can have Mach3 and Mach2 on the same system
www.machsupport.com
Re: mach2 and G76
« Reply #4 on: April 16, 2006, 09:19:18 PM »
you got an email i hope this is the file you need
marcel
Re: mach2 and G76
« Reply #5 on: April 17, 2006, 09:17:09 AM »
is this the xml file you needed
Re: mach2 and G76
« Reply #6 on: April 17, 2006, 10:23:58 PM »
Here is a shot at getting you running ...
www.machsupport.com
Re: mach2 and G76
« Reply #7 on: April 18, 2006, 04:34:40 PM »
Dear Sir
thank you very much for spending your time for me . i installed mach 3 and put the xml file you sent me when i ran the jog mode in z mode - the lathe went in x -  and when i tied z+ it went in x+ and the spindle did not turn.for the x axes they did not work.  when i tried the ball program included in mach 3 the spindle did not turn and the z axes where reversed and the x axes where ok . and thank you again for your time
marcel beaudry
Re: mach2 and G76
« Reply #8 on: April 18, 2006, 06:19:58 PM »
So I cn fix the spindle but what you are telling me is that the Jog is not working for the Z axis... That is odd... I think you need to change the axis jog keys and you will be all set :) Now for the Z axis being the wrong way I can fix that! Spindle should be working and I will have a look at that too
www.machsupport.com
Re: mach2 and G76
« Reply #9 on: April 18, 2006, 06:30:42 PM »
this one should fix everything..
www.machsupport.com
