Hello Guest it is October 22, 2026, 03:01:24 PM
Author Topic: page up, page down for z axis not working  (Read 6306 times)
« on: April 17, 2026, 02:10:34 PM »
- mach4 hobby
- installed a new computer (thinkpad 540p)
- installed all software including mach4 (with latest update)
- mach4 works correctly EXCEPT for the page up/page down function for the z axis
- put old computer back, all works well including page up/down
- put new laptop back, still no page up/down
soooo, obviously it's a configuration, not mechanical issue.
i do not know how/where to fix the configuration.
Re: page up, page down for z axis not working
« Reply #1 on: April 20, 2026, 08:59:21 AM »
is there no one that has any suggestions?
  •  9,374 9,374
« Reply #2 on: April 20, 2026, 10:47:24 AM »
Not sure this will help but…
In Diagnostic / Keyboard Inputs check that Page Up / Page Down illuminate when you press those keyboard keys. If not then change the key allocations (usually 33 / 34) to match your 540p keyboard.
Offline Bill_O
  •  615 615
« Reply #3 on: April 21, 2026, 07:24:01 AM »
If it is a number keypad make sure NumLock is off.
« Reply #4 on: August 06, 2026, 02:41:36 AM »
I ran into the same thing after moving Mach4 to a newer laptop. Everything else worked fine, but Page Up/Page Down wouldn't jog the Z axis until I checked the keyboard input assignments. It turned out to be a keyboard mapping issue rather than anything with the machine.
