Hello Guest it is October 21, 2026, 06:35:04 PM
Author Topic: "Upgrading" from Mach4 to MachPro  (Read 8711 times)
« on: January 27, 2026, 04:27:03 AM »
Hi All,
Long time no post!
I don't see it explicitly stated, but can I run MachPro on more than one machine like we do with Mach 4 or is it $550/machine?
Is there/will there be support for an analog controller?
Mike
Re: "Upgrading" from Mach4 to MachPro
« Reply #1 on: February 03, 2026, 11:55:13 AM »
Current licensing structure for MachPro will be 1 License per machine.
There is currently support and planned support for the following motion controllers:
Vital Systems: Integra , EC01
PoLabs: Pokeys57CNC, Pokeys57CNCpro4x
Warp9: ESS
Trio: Flex6x
Kingstar: Kingstar Motion
Paul
« Reply #2 on: February 03, 2026, 06:26:48 PM »
Hello Paul,
Well that is not the news I wanted to hear. I don't believe any of those will do analog motion control and I have 2 machines that require it.
As of right now, I have one supported controller and 6 or 7 unsupported controllers running a mix of Mach 3 and Mach 4.
I will have to think long and hard about upgrading to Mach-Pro since a $1K-$2K upgrade per machine would be beyond my hobby budget.
If I were to actually start a business, things might be different.
As always,
Thanks for the information.
« Reply #3 on: February 04, 2026, 09:10:45 AM »
On the note of Analog specifically, you can manage that with an EtherCAT setup or with the correct motion controller. You can do a EtherCAT connection to a Beckhoff that will control your Analog 0-10v analog signals from something like a EL4002 Or once TRIO is supported, you should be able to add a P378 Slice for Analog Outputs to the motion controller itself. What's nice about the latter option is that the TRIO is a modular solution and it has a real time PLC built in.
Paul
« Reply #4 on: February 04, 2026, 10:28:56 AM »
Hi Paul,
I am looking for analog motion, as in +-10v analog to the servo drives, not analog I/O for feedrate override and such. If that I not available, then I would have to start from scratch on 2 of my machines, which at this point is a non-starter. I do realize that +- 10 volts is old school, but there are still a lot of drives out there that work and use this interface.
Thanks again.
« Reply #5 on: February 20, 2026, 10:55:52 AM »
Currently, we don't support the old analog drives on MachPro. We are mostly trying to push into EtherCAT systems due to their reliability, safety, and functionality. At this time, the choices would be a Galil motion controller or a competitor like Centroid. At some point in the future, we may get Galil as a supported or certified motion controller, but there is no current ETA for that.
Current drives supported on MachPro when doing positional movements.
  • EtherCAT
  • Step and Direction - Differential - Open or closed loop
  • Step and Direction - Single ended - Open or closed loop (Can be done, not recommended due to reliability)
Current drives supported on MachPro when doing velocity movements. (Like a VFD)
  • EtherCAT
  • +-10v Analog
  • Serial / Modbus
  • PWM
Paul
« Reply #6 on: March 19, 2026, 07:33:38 PM »
What about the CSMIO devices? The CSMIO/A is analog (+/-10V) and uses an ethernet connection to interface the mach 4 pc.
Is there any chance of it being supported by mach pro?
« Reply #7 on: March 20, 2026, 11:52:32 AM »
Currently no. I have reached out to the company with little to no response.
Paul
« Reply #8 on: April 01, 2026, 07:11:17 PM »
Galil, Wooooo Hoooooooo!!!!!
Yes please.
Let me know if I can help with the testing.
« Reply #9 on: July 09, 2026, 09:58:48 AM »
This seems like the best thread for these questions, I hope I'm correct.  One way or another I am moving on from Mach4.  Two inexplicable machine crashes in one day have pushed me to look for alternatives.  I have a lot invested in LUA customizations that I would really like to be able to use.
1. Have there been any updates on the progress for the linux based MachPro?  I can see that the expectation on the website is 2026.  I am just wondering about the confidence level of this.
2. If I were to buy the current license, what will the policy be for moving to linux sometime in the future?
3. Lastly, I have requested a demo version of MachPro twice.  Once a couple of months ago and most recently early yesterday.  I have yet to receive any response from either request.  Has anyone else had such a challenge?  Maybe I'm being impatient with no response on my request from yesterday, but it is unusual in this day and age of software on-demand for this to be delayed.
