Hello Guest it is October 23, 2026, 04:54:34 PM
Author Topic: Mach4 full closed loop + Ethercat ??  (Read 8781 times)
« on: December 24, 2025, 03:53:42 PM »
Hi everyone,
I wanted to ask if you know whether it is possible to run Mach4 with Delta "ASDA-A2-E" drives. In a fully closed loop setup — meaning using both the motor encoders and linear glass scales?
Best Regards and happy christmas :)
Re: Mach4 full closed loop + Ethercat ??
« Reply #1 on: January 06, 2026, 03:00:46 AM »
Yes, Mach4 can be used with ASDA-A2-E in a fully closed-loop system if the closed loop is handled by the Delta drive, not by Mach4.
