Hello
Guest
it is
October 23, 2026, 03:56:35 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach4 full closed loop + Ethercat ??
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach4 full closed loop + Ethercat ?? (Read 8780 times)
madsrj8@gmail.com
1
on:
December 24, 2025, 03:53:42 PM »
Hi everyone,
I wanted to ask if you know whether it is possible to run Mach4 with Delta "ASDA-A2-E" drives. In a fully closed loop setup — meaning using both the motor encoders and linear glass scales?
Best Regards and happy christmas
Logged
girlvirtual
1
Re: Mach4 full closed loop + Ethercat ??
Reply #1 on:
January 06, 2026, 03:00:46 AM »
Yes, Mach4 can be used with ASDA-A2-E in a fully closed-loop system if the closed loop is handled by the Delta drive, not by Mach4.
Logged
Print
Pages:
1
Go Up
« previous
next »
