Hello Guest it is September 05, 2026, 11:25:23 PM
Author Topic: Macro/Script rodillos de sujeccion fresadora  (Read 90897 times)
Re: Macro/Script rodillos de sujeccion fresadora
« Reply #20 on: June 06, 2025, 02:07:44 AM »
This image
Offline TPS
  •  2,627 2,627
« Reply #21 on: June 06, 2025, 05:50:31 AM »
then there is a bug in line 15 of your code.
pls post excactly the code of the VB scripter window.
« Reply #22 on: June 06, 2025, 06:11:05 AM »
I've fixed the msg issue in the script.
The ActY takes data from the Yact machine, so it's invalid. We need MaxY and MinY from the G-code.
The code:
'Get the current values
ActY = GetOEMDro(801)
MinYCoord = GetOEMDro(5)
MaxYCoord = GetOEMDro(11)
MsgBox "ActY: " &ActY &" MinY: " &MinYCoord &" MaxYcoord; " &MaxYCoord
'front lowering
If ActY >= (MinYCoord) Then'<=
ActivateSignal(OUTPUT11)
End If
'front raising
If ActY <= (MinYCoord) Then'<=
DeActivateSignal(OUTPUT11)
End If
'rear lowering
If ActY >= (MaxYCoord) Then'<=
ActivateSignal(OUTPUT10)
End If
'front raising
If ActY <= (MaxYCoord) Then'>=
DeActivateSignal(OUTPUT10)
End If
If(GetInBit(90, 2)) And Not (GetOemLed(800)) Then
   Code(" G55")
   Espera
   If getDro (24) = 2 Then
      Code("G52 X-275.95 Y167.36 ")
      Espera
   End If
   If getDro (24) = 3 Then
      Code("G52 X-551.09 Y-2.87 Z0")
      Espera
   End If
   Espera
End If
If(GetInBit(90, 3)) And Not (GetOemLed(800)) Then
   Code(" G56")
   Espera
      Espera
   End If
      Espera
   End If
End If
End
Sub Espera ()
   While IsMoving()
      Sleep(15)
   Wend
End Sub
Offline TPS
  •  2,627 2,627
« Reply #23 on: June 06, 2025, 10:38:40 AM »
if i load i simple G-code here i can see the Min/Max values from G-Code program in program limit's
this is what OEMDro(5) and OEMDro(11) are normaly showing.
and ActY is what this Axis DRO is showing
« Reply #24 on: June 06, 2025, 12:08:31 PM »
If you look at the message generated in the VB script, the ActY value is the machine coordinate.
The MinY value refers to the minimum absolute machine coordinate.
Only the MaxY value is actually how we want to compare it with the MaxY in G code.
This is strange, since, as you say, 5 and 11 refer to G code.
Only OEM Dro 11 is working as we want.
« Reply #25 on: June 07, 2025, 01:04:21 AM »
The OEMDRO 801 is a multifunction device that can be used for Machine Coordinates, Work, or DTG. How do we select one of these three functions?
Offline TPS
  •  2,627 2,627
« Reply #26 on: June 07, 2025, 01:36:10 AM »
here:
https://www.machsupport.com/forum/index.php?topic=19482.0
you can download a list of all DRO's / OEMDro's
OEMDro(801) is the current Y-Coord
Dro(84) is Y-MachineCoord
and there a couple of other's
i usually allways use OemDro(801)
Offline TPS
  •  2,627 2,627
« Reply #27 on: June 07, 2025, 01:43:52 AM »
maybe OEMDro(185) will do the job
« Reply #28 on: June 08, 2025, 02:20:20 AM »
Okay, thanks, friend. The variables are correct. I don't understand why it's not collecting the information about the Gcode. Would it be possible to add an option so that it only starts executing these script functions after requesting the Gcode program to start?
Offline TPS
  •  2,627 2,627
« Reply #29 on: June 08, 2025, 03:56:20 AM »
okay this is a version witch is only excecuted if Cycle Start LED is ON
Code: [Select]
'only if Start LED is only
If GetOEMLed(804) = True Then
'front lowering
End If
'front raising
End If
'rear lowering
End If
'front raising
End If
End If
