Hello Guest it is October 20, 2026, 02:03:52 PM
Author Topic: Macro/Script rodillos de sujeccion fresadora  (Read 94025 times)
Re: Macro/Script rodillos de sujeccion fresadora
« Reply #30 on: June 20, 2025, 02:13:00 AM »
Hi, the problem was that the machine was using a very old version of Mach3. I'm going to install a new version of Mach3 so I can use it.
The current version of the machine has an ATC, so the operator can manually select the tool number they want to use. How can I configure this?
Another problem I have when using the new version of Mach3 is that the axes move very slowly, at low speeds. How can I increase the speed?
« Reply #31 on: July 06, 2025, 10:13:27 AM »
Hello my friend.
I'm still having problems regarding the minimum Y...
I'm attaching two photos. The minimum Y in G code is Y100. Look at the value Mach3 displays.
Offline TPS
  •  2,627 2,627
« Reply #32 on: July 06, 2025, 10:16:19 AM »
hello,
can you pls. post your GCode so i can test here?
Thank You
« Reply #33 on: July 06, 2025, 10:35:04 AM »
Hola, claro publico aqui el codigo G
He descubierto que una macro, es la que me altera los valores, ''fixture.dat'', pero aun asi me sigue marcando el valor MinY como 0
Offline TPS
  •  2,627 2,627
« Reply #34 on: July 06, 2025, 12:09:18 PM »
if i test your posted GCode here, everything looks fine.
« Reply #35 on: July 08, 2025, 08:10:16 AM »
There is a macro that generates this malfunction in mach3
« Reply #36 on: January 10, 2026, 07:10:03 AM »
Hello friend and happy New year.
I have a problem in other machine.
I have installed a csmio ip-s and I have a problem with Mach 3, when resetting Mach 3 to remove the emergency, it activates the activation output of the spindle, can you help me?
Offline TPS
  •  2,627 2,627
« Reply #37 on: January 10, 2026, 07:34:16 AM »
only thing i can imagine that in
Config -> Ports&Pins -> Output Signal's one of the enable output's is
assigned to the spindle enable Output.
otherwise post your Config file here.
« Reply #38 on: January 10, 2026, 08:13:18 AM »
Yes, that is the assigned output, but mach3 activates the spindle without running g code.
Offline TPS
  •  2,627 2,627
« Reply #39 on: January 10, 2026, 08:27:40 AM »
the enable output's in
Config -> Ports&Pins -> Output Signal's will allways be enabled after reset E-Stop
spindle outputs are assigned in
Config -> Ports&Pins -> Spindle setup
one Mach3 outputnumber for CW (M3)
and an other Mach3 outputnumber for CCW (M4)
and then in
you have to assign the "real" output from your CSMIO/S
