Hello Guest it is October 30, 2026, 11:20:39 AM
Author Topic: Macro/Script rodillos de sujeccion fresadora  (Read 122576 times)
Re: Macro/Script rodillos de sujeccion fresadora
« Reply #10 on: April 13, 2025, 02:44:47 AM »
With GetOEMDro(801), can I use it for the two functions shown in the attached files?
I need to work with those two, MaxY and MinY.
Offline TPS
  •  2,627 2,627
« Reply #11 on: April 13, 2025, 02:46:44 AM »
i mean:
ActY = GetOEMDro(801)
it will not effect the Min and Max.
« Reply #12 on: April 13, 2025, 02:53:01 AM »
I need to compare the current position of the machine with the minimum and maximum Y values ​​in the G code, to raise or lower the rollers when they are close to the maximum and minimum Y limits.
Offline TPS
  •  2,627 2,627
« Reply #13 on: April 13, 2025, 02:56:12 AM »
that is what the code does? if you are using G54,G55 .. it should do it during you run your G-code program.
« Reply #14 on: April 13, 2025, 03:04:43 AM »
I'll try ActY = GetOEMDro(801).
Thank you.
If we are using G55 and G56
« Reply #15 on: May 24, 2025, 12:26:34 PM »
Hi friend. How are you?
I can't get this macro to work properly, please help me.
It only activates output 10, but it's fixed and doesn't do what I need: deactivate when it reaches the limit.
It also never activates output 11, even though it's in the working position.
I'm uploading the code here for you to review. I think I'm missing some actions.
Offline TPS
  •  2,627 2,627
« Reply #16 on: May 25, 2025, 02:01:20 AM »
there is still a bug in your script:
  rear lowering
should be:
  'rear lowering
witch i have written earlier, anyway you can copy this code:
Code: [Select]
'Get the current values
MinYCoord = GetOEMDro(5)
MaxYCoord = GetOEMDro(11)
MsgBox "ActY: " &ActY &" MinY: " &MinYCoord &" MaxYcoord; " &MaxYCoord
'front lowering
If ActY <= (MinYCoord+80) Then
ActivateSignal(OUTPUT10)
MsgBox "OUTPUT10 activated"
End If
'front raising
If ActY > (MinYCoord+80) Then
DeActivateSignal(OUTPUT10)
MsgBox "OUTPUT10 deactivated"
End If
'rear lowering
If ActY <= (MaxYCoord-80) Then
ActivateSignal(OUTPUT11)
MsgBox "OUTPUT11 activated"
End If
'front raising
If ActY > (MaxYCoord-80) Then
DeActivateSignal(OUTPUT11)
MsgBox "OUTPUT11 deactivated"
End If
into VB Scripter Window and use  >||  button to step through programm to see what is going on.
a GGode programm has to be loaded to have valid MinY and MaxY coords. then you can move y axis in manual and step throug programm again.
« Reply #17 on: June 06, 2025, 01:14:18 AM »
Hola, he escrito el código tal cual me lo ha enviado y no funciona. La maquina solo activa la salida 11, fija durante todo el mecanizado, sin subir cuando se acerca al limite. Y al finalizar el mecanizado activa las dos salidas 10 y 11.
Offline TPS
  •  2,627 2,627
« Reply #18 on: June 06, 2025, 01:34:55 AM »
copy this code:
Code: [Select]
into VB Scripter window and press the run button, then you will get a messagebox with coordinates
to see the real coordinates and post the  result
« Reply #19 on: June 06, 2025, 01:55:41 AM »
This mesag in the screen
