Hello
Guest
it is
October 21, 2026, 08:16:06 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Mach3 How to add a saved BU file "MACH3MILL. XB1" to replace mach default settin
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach3 How to add a saved BU file "MACH3MILL. XB1" to replace mach default settin (Read 8978 times)
Mr.Chips
68
on:
November 28, 2024, 07:13:45 AM »
I downloaded a fresh version of Mach3 and want to import a older backup file to replace the default settings in Mach. Can you tell me how to do that?
Mr. Chips
Retired 3M'r
Tweakie.CNC
9,374
Super Kitty
Re: Mach3 How to add a saved BU file "MACH3MILL. XB1" to replace mach default settin
Reply #1 on:
November 28, 2024, 09:16:23 AM »
Select the backup that you require and change its file extention (eg. from Mach3Mill.
xb1
to Mach3Mill.
xml
) and copy it into your Mach3 folder (replace the existing Mach3Mill.xml).
Last Edit: November 28, 2024, 09:45:19 AM by Tweakie.CNC
Print
Pages:
1
Go Up
« previous
next »
