Hello Guest it is September 22, 2026, 04:23:32 AM
Author Topic: Mach3 How to add a saved BU file "MACH3MILL. XB1" to replace mach default settin  (Read 8858 times)
I downloaded a fresh version of Mach3 and want to import a older backup file to replace the default settings in Mach.  Can you tell me how to do that?
Mr. Chips
Retired 3M'r
  •  9,373 9,373
Select the backup that you require and change its file extention (eg. from Mach3Mill.xb1 to Mach3Mill.xml) and copy it into your Mach3 folder (replace the existing Mach3Mill.xml).
« Last Edit: November 28, 2024, 09:45:19 AM by Tweakie.CNC »
