Hello Guest it is October 24, 2026, 08:25:10 PM
Author Topic: G54 nullen bei bie Mach4 Programmstart  (Read 9715 times)
« on: November 03, 2024, 09:47:14 AM »
Hello,
When I start Mach4 I want to have G54 X0 Y0 Z0.
Is that possible????
With Mach3 you could set that.
Hallo,
wenn ich Mach4 starte möchte ich G54 X0 Y0 Z0 haben.
Ist das möglich ????
Bei Mach3 konnte mann das einstellen.
« Last Edit: November 03, 2024, 11:54:38 PM by Tweakie.CNC »
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: G54 nullen bei bie Mach4 Programmstart
« Reply #1 on: November 04, 2024, 02:57:32 PM »
Just add the code in this screen.
« Reply #2 on: November 05, 2024, 08:53:44 AM »
Thank you Graham.
I've already tried that, but unfortunately it doesn't work with the input of G54 X0 Y0 Z0.
Best wishes Andreas
  •  2,785 2,785
« Reply #3 on: November 05, 2024, 05:31:07 PM »
Can you explain just what you are wanting to do?
Are you expecting the machine to move to G54 X0 Y0 Z0 or something else to happen?
« Reply #4 on: November 06, 2024, 07:43:10 AM »
Wouldn't that be kind of risky, to have the machine move on an initialization code like this?
If Mach4 shuts down improperly, you lose your work offsets; what's to say that X0Y0Z0 is an undesirable position if this happens?
Chad Byrd
