Hello
Guest
it is
November 24, 2026, 11:09:10 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
G54 nullen bei bie Mach4 Programmstart
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: G54 nullen bei bie Mach4 Programmstart (Read 9993 times)
Formula272
9
on:
November 03, 2024, 09:47:14 AM »
Hello,
When I start Mach4 I want to have G54 X0 Y0 Z0.
Is that possible?
With Mach3 you could set that.
Hallo,
wenn ich Mach4 starte möchte ich G54 X0 Y0 Z0 haben.
Ist das möglich
Bei Mach3 konnte mann das einstellen.
Last Edit: November 03, 2024, 11:54:38 PM by Tweakie.CNC
Logged
Graham Waterworth
2,785
Yorkshire Dales, England
Re: G54 nullen bei bie Mach4 Programmstart
Reply #1 on:
November 04, 2024, 02:57:32 PM »
Just add the code in this screen.
Logged
Formula272
9
Reply #2 on:
November 05, 2024, 08:53:44 AM »
Thank you Graham.
I've already tried that, but unfortunately it doesn't work with the input of G54 X0 Y0 Z0.
Best wishes Andreas
Logged
Graham Waterworth
2,785
Reply #3 on:
November 05, 2024, 05:31:07 PM »
Can you explain just what you are wanting to do?
Are you expecting the machine to move to G54 X0 Y0 Z0 or something else to happen?
Logged
Cbyrdtopper
985
Reply #4 on:
November 06, 2024, 07:43:10 AM »
Wouldn't that be kind of risky, to have the machine move on an initialization code like this?
If Mach4 shuts down improperly, you lose your work offsets; what's to say that X0Y0Z0 is an undesirable position if this happens?
Logged
Chad Byrd
Print
Pages:
1
Go Up
« previous
next »
