Hello Guest it is October 25, 2026, 11:47:57 PM
Author Topic: Issue with CNC Y Direction  (Read 21652 times)
« on: October 31, 2024, 05:53:54 AM »
My machine is stopping but Mach3 seems to think it's still running then it starts moving again when it had to go to a X direction. This makes it out of registration. Im it's likely a software fault but i don't know whats causing it. I have ruined 3 boards and i cant get it working correctly.
Can anyone help?
  •  9,374 9,374
Re: Issue with CNC Y Direction
« Reply #1 on: October 31, 2024, 05:58:29 AM »
If you post your <your profile> .xml file (typically Mach3Mill.xml) I will take a look at your settings and see if anything is amiss.
« Reply #2 on: October 31, 2024, 06:27:38 AM »
Thanks for replying. Im not sure where i can find this file to be honest. Also im not on the same computer as the machines right now because i have come home to see if i can work it out somehow.
  •  9,374 9,374
« Reply #3 on: October 31, 2024, 06:33:49 AM »
You need the .xml file from the computer that has the problem. The file is in your Mach3 folder.
This thread details how to add attachments to your posting https://www.machsupport.com/forum/index.php?topic=24585.0
« Last Edit: October 31, 2024, 06:36:02 AM by Tweakie.CNC »
« Reply #4 on: October 31, 2024, 08:43:15 AM »
I keep getting this message so i have had to change the name
An Error Has Occurred!
Sorry! There is already an attachment with the same filename as the one you tried to upload. Please rename the file and try again.
  •  9,374 9,374
« Reply #5 on: October 31, 2024, 10:44:51 AM »
I don’t see any problems with your Mach3 machine setup and there have not been any Y axis stopping problems reported with the UC100 motion controller.
My best suggestion is that you check your machine for tightness of the Y axis motor coupling or binding in the axis movement.
Also check connection of wiring to the Y axis driver and to the stepper motor itself.
Hope this helps.
« Reply #6 on: October 31, 2024, 01:05:40 PM »
Hope this helps.
One thing i need to point out is that the connection cable is in Two parts due to the distance from the machine to the Computer. Could that be part of the problem or indeed tha cause? I didnt give this any thought before.
I also have another question. My machine runs as 12,000 RPM. Is this the correct speed? it allows me to speed up to 16,000 but that over ride doesnt seem to work.
  •  9,374 9,374
« Reply #7 on: November 01, 2024, 01:10:46 AM »
I have one machine that uses a 5 meter LPT cable without any issues but I would not want to use a USB cable any longer than say 1 meter. Extending cables is generally not good practice but if they are of good quality with gold plated pin and socket connections then it should not be a problem.
Just as a test try reducing the Velocity and Acceleration of your Y axis in motor tuning by 50%, saving the changes. Does it now still have the problem ?
« Reply #8 on: November 01, 2024, 01:25:21 AM »
I will try anything to be honest. How do i reduce the Velocity and Acceleration of the Y Axis?
« Reply #9 on: November 01, 2024, 01:28:37 AM »
found id
