Hello Guest it is October 25, 2026, 10:55:49 PM
Author Topic: Mach3 and LazyCAM  (Read 15545 times)
Mach3 and LazyCAM
« on: September 25, 2024, 02:28:31 PM »
I draw my projects to scale in my CAD program, save it as DXF, export it into Lazy CAM and when it posts G-Code to Mach3, it comes out real small in Mach3.  Any suggestions here?  Thanks
Re: Mach3 and LazyCAM
« Reply #1 on: September 26, 2024, 12:34:13 AM »
CAD/CAM set to inches but Mach3 to mm?
« Reply #2 on: September 26, 2024, 10:05:19 AM »
Hi John.  When I used Mach3 begore with my mini mill, it w03ked in inches.  That is ok, I can draw in metric.  In motor tuning, I am using inches.
« Reply #3 on: September 26, 2024, 12:17:11 PM »
I just wondered if there was a units incompatibility leading to a 25.4:1 reduction in size.
« Reply #4 on: September 26, 2024, 07:25:37 PM »
Worth researching.
« Reply #5 on: September 27, 2024, 04:36:56 AM »
Post your g-code?  Have you checked the machine moves the commanded distance when you jog it or use the MDI?  AFAIK (just checked again) there's nothing in motor tuning to select inches or mm.  There is a "Steps per" box which is steps (including microsteps) per native unit - which are set in "config\native units".
« Reply #6 on: September 27, 2024, 09:13:23 PM »
John, I drew in Inches and just before saving the drawing as a DXFI converted to mm.  When I entered it in Lazy CAM, I changed scale from mm to inches and it worked ok that way.  That may have been the way I got around it before.
