Hello
Guest
it is
October 24, 2026, 07:33:03 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach3 and LazyCAM
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach3 and LazyCAM (Read 15518 times)
ironman123
52
Mach3 and LazyCAM
on:
September 25, 2024, 02:28:31 PM »
I draw my projects to scale in my CAD program, save it as DXF, export it into Lazy CAM and when it posts G-Code to Mach3, it comes out real small in Mach3. Any suggestions here? Thanks
Logged
JohnHaine
975
Re: Mach3 and LazyCAM
Reply #1 on:
September 26, 2024, 12:34:13 AM »
CAD/CAM set to inches but Mach3 to mm?
Logged
ironman123
52
Reply #2 on:
September 26, 2024, 10:05:19 AM »
Hi John. When I used Mach3 begore with my mini mill, it w03ked in inches. That is ok, I can draw in metric. In motor tuning, I am using inches.
Logged
JohnHaine
975
Reply #3 on:
September 26, 2024, 12:17:11 PM »
I just wondered if there was a units incompatibility leading to a 25.4:1 reduction in size.
Logged
ironman123
52
Reply #4 on:
September 26, 2024, 07:25:37 PM »
Worth researching.
Logged
JohnHaine
975
Reply #5 on:
September 27, 2024, 04:36:56 AM »
Post your g-code? Have you checked the machine moves the commanded distance when you jog it or use the MDI? AFAIK (just checked again) there's nothing in motor tuning to select inches or mm. There is a "Steps per" box which is steps (including microsteps) per native unit - which are set in "config\native units".
Logged
ironman123
52
Reply #6 on:
September 27, 2024, 09:13:23 PM »
John, I drew in Inches and just before saving the drawing as a DXFI converted to mm. When I entered it in Lazy CAM, I changed scale from mm to inches and it worked ok that way. That may have been the way I got around it before.
Logged
Print
Pages:
1
Go Up
« previous
next »
