Hello Guest it is October 25, 2026, 09:04:25 PM
Author Topic: Mach3 with USB  (Read 25430 times)
Re: Mach3 with USB
« Reply #10 on: September 14, 2024, 06:52:24 PM »
My DRO's on Mach3 do not show to scale,
 like I move my Z axis from zero up 2.5 inches but it reads 39.985.  What do I need to do to get it to read proper inches?
Re: Mach3 with USB
« Reply #11 on: September 15, 2024, 04:08:57 AM »
2.5" as a G0 move or measured? Ditto 39.985? What is your leadscrew pitch?  I think you need to go right through the machine configuration checking everything, especially steps/unit given your screw pitch and any reduction between motor and screw, and the microstep setting on the drivers.  Read and understand the manual.  Make sure you don't have a scaling factor configured.
Re: Mach3 with USB
« Reply #12 on: September 15, 2024, 03:41:42 PM »
Ball screw/Lead screw pitch is .2
