Hello Guest it is October 24, 2026, 08:42:29 PM
Author Topic: Driver has a Question Mark  (Read 25300 times)
Re: Driver has a Question Mark
« Reply #10 on: July 21, 2024, 06:12:19 AM »
Hi, If that is the .xml under my Mill Install this is it. Otherwise let me know where to locate it please.
Regards
« Reply #11 on: July 21, 2024, 07:47:10 AM »
The one for the profile your are using. let me brows through it and I will get back to you.
Regards
Charlie M.
« Reply #12 on: July 22, 2024, 03:52:05 AM »
Also another thing to check is your parallel p[ort settings in the BIOS. You may have 2 options. ECP and EPP. If so then make sure your are set to EEP.
Regards
Charlie M.
« Reply #13 on: July 22, 2024, 04:52:28 AM »
Hello, should it be ECP or EPP.
« Reply #14 on: July 22, 2024, 05:41:06 AM »
EPP.
Regards
Charlie M.
