Hello Guest it is October 24, 2026, 08:44:21 PM
Author Topic: Driver has a Question Mark  (Read 25301 times)
« on: July 20, 2024, 07:29:21 PM »
Hello, I am setting up a 6040 from scratch. My first hurdle is a question mark showing in the driver icon in device manager. Any one have any ideas what could be amiss with me or my system, TIA
Re: Driver has a Question Mark
« Reply #1 on: July 21, 2024, 04:43:59 AM »
 How does your 6040 connect to the PC? USB or Printer port?
Regards
Charlie
Regards
Charlie M.
« Reply #2 on: July 21, 2024, 04:53:27 AM »
Hello, I connect with a parallel port. Thanks
« Reply #3 on: July 21, 2024, 05:02:33 AM »
Can you post a screen shot of the device manager? When you install Mach3 It installs a Parallel port Driver. You may need to
Reinstall Mach3. What version Of windows are you running? and Is it 32 or 64 bit?
Regards
Charlie M.
« Reply #4 on: July 21, 2024, 05:15:54 AM »
Hello, Win7 32 bit. Was a clean install from Mach3. Attached .jpg shows my problem, thanks
« Reply #5 on: July 21, 2024, 05:20:21 AM »
 All I see is it says No conflicts. I assume that you machine wont move?
Regards
Charlie M.
« Reply #6 on: July 21, 2024, 05:31:36 AM »
Correct the moto will not move. I have the question mark on the driver in device manager. I have put a parallel port monitor on the PC which indicates pulses going to the motor. The DRO responds when hitting the manual keys. The pinouts on the parallel port respond to the settings in Mach3. When applying a current direct to the motor it jumps, i guess just one pulse.
« Reply #7 on: July 21, 2024, 05:42:52 AM »
Can you try something? In the printer port properties uncheck the checkbox labeled " Use Automatic Settings" and see what happens. you may have to restart the computer for the settings to take effect.
Regards
Charlie M.
« Reply #8 on: July 21, 2024, 05:55:17 AM »
Hello, I changed it and restarted but unfortunately nothing changed. Frustrating
« Reply #9 on: July 21, 2024, 06:03:28 AM »
can you upload you xml file?
Regards
Charlie M.
