Hello
Guest
it is
October 24, 2026, 07:33:28 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Driver has a Question Mark
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Driver has a Question Mark (Read 25290 times)
Steve1307
11
Re: Driver has a Question Mark
Reply #10 on:
July 21, 2024, 06:12:19 AM »
Hi, If that is the .xml under my Mill Install this is it. Otherwise let me know where to locate it please.
Regards
Logged
Charlie_M
189
Reply #11 on:
July 21, 2024, 07:47:10 AM »
The one for the profile your are using. let me brows through it and I will get back to you.
Logged
Regards
Charlie M.
Charlie_M
189
Reply #12 on:
July 22, 2024, 03:52:05 AM »
Also another thing to check is your parallel p[ort settings in the BIOS. You may have 2 options. ECP and EPP. If so then make sure your are set to EEP.
Logged
Regards
Charlie M.
Steve1307
11
Reply #13 on:
July 22, 2024, 04:52:28 AM »
Hello, should it be ECP or EPP.
Logged
Charlie_M
189
Reply #14 on:
July 22, 2024, 05:41:06 AM »
EPP.
Logged
Regards
Charlie M.
Print
Pages:
1
2
Go Up
« previous
next »
