Hello Guest it is November 01, 2026, 01:42:56 PM
Author Topic: Setting Depth of cut ??  (Read 16734 times)
esmiller
« on: April 14, 2006, 08:52:46 PM »
How do i set the depth of cut? When i set it to 0.1", it shows up in Mach 3 as Min Z: .0914: and Max Z as:+1.000
I must have missed something obvious.. am gonna watch the video again, since i must have missed something, but only place i can find to set Depth of Cut is under the Rast XY option, i set total Depth to .100 Max
Am i missing something obvious?
Eddie
*EDIT* forgot to mention that this is with the IMAGE load option, as i am trying to carve a picture of my wife for a belated B-Day gift. Didn't forget it, just haven't gotten it successfully carved yet..
« Last Edit: April 14, 2006, 09:30:30 PM by esmiller »
Re: Setting Depth of cut ??
« Reply #1 on: April 15, 2006, 03:35:04 PM »
There must not be any true BLACK in the Pic... The depth should go to -.1 in a BLACK section of the pic.
www.newfangledsolutions.com
www.machsupport.com
esmiller
« Reply #2 on: April 15, 2006, 05:00:16 PM »
Actually, i got a response from Art regarding this issue, which is as follows:
>Imaging really wasnt quite ready, the depths are backwards. Youd need to
>put -1 scale in the Z in Mach to get one to cut. Next version shoudl fix
>that. Total depth of cut is the depth selector. In either spiral or raster.
>You cannot set the rapid as yet. IT wil lgo at 1" to the start and it never
<really lifts from there, it just carves along in the image cut till the end.
<Should be fixed by monday or so...
thanks Art for the prompt response to this question. you always respond much more quickly then I ever expect!
