Hello Guest it is October 24, 2026, 10:34:56 PM
Author Topic: Lathe spindle encoder  (Read 13580 times)
« on: April 28, 2024, 09:54:46 AM »
I’m looking for spindle encoder recommendations I’m using ESS with mb3 board and I’m definitely going to do threading. I’m curious to know what this group has had good luck with.
Art
Re: Lathe spindle encoder
« Reply #1 on: April 29, 2024, 10:13:54 AM »
« Reply #2 on: May 12, 2024, 07:49:24 AM »
Thanks for that, but I already have a 5hp marathon motor running on a vfd my question was what encoder are people using for rpm feed back and for threading?
Art
« Reply #3 on: May 12, 2024, 07:56:52 AM »
Usually a low resolution encoder 100 to 500 PPR.
We offer this one:
https://cnc4pc.com/rotary-encoder-kit.html
Arturo Duncan
https://cnc4pc.com
« Reply #4 on: May 12, 2024, 04:43:42 PM »
Does M4 need a i ppr index pulse as well as an encoder?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #5 on: May 12, 2024, 06:32:57 PM »
I use the Z channel on the encoder for the index pulse.
« Reply #6 on: May 13, 2024, 03:33:46 AM »
Thanks Graham.  So the answer is yes, and the encoder either needs to have a z channel or a separate 1 ppr sensor.
« Reply #7 on: May 13, 2024, 09:03:38 AM »
Note that if you use the Z channel of the encoder, the encoder must be "geared" 1:1 with the spindle.
Steve Stallings
www.PMDX.com
