Hello
Guest
it is
October 24, 2026, 06:46:25 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Lathe spindle encoder
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Lathe spindle encoder (Read 13566 times)
menardmfg
70
on:
April 28, 2024, 09:54:46 AM »
I’m looking for spindle encoder recommendations I’m using ESS with mb3 board and I’m definitely going to do threading. I’m curious to know what this group has had good luck with.
Art
Logged
arturod
172
Re: Lathe spindle encoder
Reply #1 on:
April 29, 2024, 10:13:54 AM »
This is how this is done:
https://www.cnc4pc.com/blog/post/con...tepper-and-c82
Check this out:
https://youtu.be/1cx5qVEXGrk
This will give you an idea:
Arturo Duncan
https://cnc4pc.com
Logged
menardmfg
70
Reply #2 on:
May 12, 2024, 07:49:24 AM »
Thanks for that, but I already have a 5hp marathon motor running on a vfd my question was what encoder are people using for rpm feed back and for threading?
Art
Logged
arturod
172
Reply #3 on:
May 12, 2024, 07:56:52 AM »
Usually a low resolution encoder 100 to 500 PPR.
We offer this one:
https://cnc4pc.com/rotary-encoder-kit.html
Arturo Duncan
https://cnc4pc.com
Logged
JohnHaine
975
Reply #4 on:
May 12, 2024, 04:43:42 PM »
Does M4 need a i ppr index pulse as well as an encoder?
Logged
Graham Waterworth
2,785
Yorkshire Dales, England
Reply #5 on:
May 12, 2024, 06:32:57 PM »
I use the Z channel on the encoder for the index pulse.
Logged
JohnHaine
975
Reply #6 on:
May 13, 2024, 03:33:46 AM »
Thanks Graham. So the answer is yes, and the encoder either needs to have a z channel or a separate 1 ppr sensor.
Logged
Steve Stallings
529
Reply #7 on:
May 13, 2024, 09:03:38 AM »
Note that if you use the Z channel of the encoder, the encoder must be "geared" 1:1 with the spindle.
Logged
Steve Stallings
www.PMDX.com
Print
Pages:
1
Go Up
« previous
next »
