Hello Guest it is November 22, 2026, 07:50:25 AM
Author Topic: Driver Installation question  (Read 192556 times)
« on: November 14, 2007, 01:46:55 PM »
I have a How-To questions about the driver located in this thread.  http://www.machsupport.com/forum/index.php/topic,4827.msg33471.html#msg33471
Can you provide a thumbnail of directions about how to install that driver?
Copy it into the Mach3 folder I presume.   Which subfolder.  It's been a while since in installed any Mach3 drivers.
Thanks in advance.
Re: Driver Installation question
« Reply #1 on: November 14, 2007, 02:17:19 PM »
Put the .m3p file in the mach3 folder, double click it to install it, and start mach3.   It's more of a Plugin than a driver.
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« Reply #2 on: November 14, 2007, 05:56:27 PM »
Yup, M3P files stands for "Mach 3 Plugin" and they are autoinstalling, I just copy them to my desktop, and double click it. It will go away and install itself to the right spot..
After that, you need to run MAch3, select config/config plugins, check the enable box beside the "3d Probing Plugin" lline, and restart mach3. The video prober will then appear in your menus'.
Art
( M3S files are mach3 screens... same deal.. )
« Reply #3 on: November 17, 2007, 09:40:32 AM »
Art,
I installed the driver.  I started M3 and using Config/config pulgins, I enabled the 3dVideo.  I immediately got this message:
"Error triggered, Error found, Art Code: 9991, Attempt Recovery"  It was a little window popup.
I do not have a video camera hooked up yet, could that be the problem?
« Last Edit: November 18, 2007, 12:45:49 PM by DavidCousins »
« Reply #4 on: November 18, 2007, 12:48:09 PM »
I thought I bump this topic, as I still can't install the video probe.   One more thing I did was reboot my computer after getting the error message.   But after rebooting, I found Mach3 would crash during startup.  To solve that problem, I deleted the video..dll file I found in the plugins directory.  That fixed the immediate crash problem.
Any thoughts?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #5 on: November 18, 2007, 01:30:00 PM »
I could only get it to work right with version 2.60, my previous version 2.58 gave the same error as you are getting.
It must also be stored in the C:\Mach folder.
Graham.
« Reply #6 on: November 18, 2007, 02:41:22 PM »
Graham,
Thanks, that fixed it.    Now, I'm off to figure out a mount for my webcam and laser.
Also, I realize that my camera appears to be B/W.  I wonder if that will be an issue.
« Last Edit: November 18, 2007, 08:28:27 PM by DavidCousins »
« Reply #7 on: November 25, 2007, 09:26:55 PM »
I have more questions.  I've got the camera operational, and the software running.
Actually the camera is marginally running.  But it works well enough for the 3DVideoProbe to operate.  Here's what I know.
1st, I calibrate and I get a Scan Angle.
2nd, I change the feed rate to 5 (assuming its in/min, what should it be?)
3rd, I change the StepOverX to .01  (What should it be?)
4th, I changed the ScanX to 2 (because my object is 2 inches wide)
5th, I press Scan  (The table moves 2 inches at 5 in/min then returns).
What else am I supposed to do, and what indication do I get when the txt file is created?
I have aquestion about frame rates.   Does 3DVideoProbe match one frame of video to each "StepOverX"?
Regarding "camera control", I'm assuming that once I configure the camera to get the best resolution, I can ignore the startVideo stopvideo.
When do I press Stop Digitizing?
« Last Edit: November 26, 2007, 08:54:54 AM by DavidCousins »
« Reply #8 on: November 26, 2007, 08:57:20 AM »
I thought I'd bump this thread.
Any comments about my questions above?
What should the StepoverX be?
Offline ART
  •  1,703 1,703
« Reply #9 on: November 26, 2007, 09:47:51 AM »
Hi David:
I
>>Whatever you like.. Feedrate is in your current units/minute..
>>Leave it alone till next release, you shoudl be scanning in Y only..
>>No, make the Y scan the 2"s , perhaps at .1 inch of YStepover
>>Y shoudl move, it will take 640 samples of the X with each Y movement..
>>The file points.txt is now in your mach3 folder..
No, it actually uses several frames per step, but as I say, stick with Y scanning only for now..
 True, not needed to be used..
 Only if you need to stop a scan or abort it..
Art
