Hello Guest it is November 11, 2026, 07:04:19 PM
Author Topic: delay the start of processing  (Read 15272 times)
« on: February 12, 2024, 11:51:29 AM »
Good morning
I would like to delay the processing after turning on the spindle (m3) to give it time to reach the spindle revolutions. I tried in " config \port and pins\spindle setup\cv delay spin up and cw delay spin down) to insert various values from 1 to 10 but nothing changes
I'll start by saying that I use UC400ETH, Windows XP everything else works fine, is it possible to modify M3, any ideas/suggestions?
any advice is welcome.
Offline TPS
  •  2,627 2,627
Re: delay the start of processing
« Reply #1 on: February 13, 2024, 11:42:31 AM »
time depends on setting in:
Config -> General Config -> General Cinfiguration -> G04 dwell in ms
if this is enabed also "delay spin up" will be in ms
« Reply #2 on: February 13, 2024, 12:10:26 PM »
ok, actually in "Config -> General Config -> General Cinfiguration -> G04 dwell in ms" it is enabled, do you recommend disabling it or entering 5000?
thanks for the reply regards
Offline TPS
  •  2,627 2,627
« Reply #3 on: February 14, 2024, 12:20:26 AM »
either way is ok.
