Hello Guest it is November 13, 2026, 02:52:38 PM
Author Topic: UC300 turning on water cooler with the spindle  (Read 16257 times)
« on: February 11, 2024, 02:42:32 AM »
I have a CNC machine with UC300 controller, 2.2K water cooled spindle.
How can I define in the software that the water pump will be activated automatically when the spindle is running?
(through a relay of course)
Re: UC300 turning on water cooler with the spindle
« Reply #1 on: February 11, 2024, 04:55:41 AM »
Good morning
I (in my small way) connected it directly to the HUANYANG VFD
It has a built-in relay which when active the spindle trips and the pump starts
Greetings
« Reply #2 on: February 11, 2024, 07:43:12 AM »
Good morning
Greetings
ok. tnx.
How many amperes can this relay carry ?
Did you use another relay that it activates ?
« Last Edit: February 11, 2024, 07:45:34 AM by niki21 »
« Reply #3 on: February 11, 2024, 09:18:44 AM »
yes, with the output from the VFD I control another relay for the pump
Greetings
« Reply #4 on: February 11, 2024, 12:28:04 PM »
Thank you.
